Hi are there any bulk head holes/grommets that would be easy to run a cable through into the car drivers side for a air horn switch then reseal with silicone,I don't want to use the original horn set up I'll keep them separate thanks
speedrules1 314 posts · Joined 2011 Add to quote Only show this user #2 · Sep 20, 2019 Usually if the hole is drilled correctly and a correct sized good grommet is used no silicone will be required.
O ol'trucker Discussion starter 52 posts · Joined 2019 Add to quote Only show this user #3 · Sep 20, 2019 Hi speedrules1 thanks for the info .
