Ok, I am not 100% sure if I am even in the right area for this. I was informed by several installers that I am going to need to bypass the onboard amp to get my aftermarket equipment to work, what I am wanting to do is use the existing headunit and put in an amp to control my mids and highs, and another amp to control my sub.
Do I need to bypass the onboard amp to do this, if so will I lose my steering wheel controls?
Any guidance you guys can provide would be greatly appreciated.
I am new to the forums
The answer is NO, you don't "have" to bypass the amp. In fact
does your car have Navvoice or Uconnect? If it does, you want
to keep the amp in the chain otherwise you'll lose the audio for
those features.
First things to confirm is your car actually has an amp, you didn't mention
which sound group option the car came with. If it is sound group I or
II, or says "Boston Acoustics", they you definitely have an amp.
If so, you have options:
1. PAC c2a-chy: This is an adapter that gives you 2 sets of pre-outs to
add aftermarket amps, plus the pre-outs
2. JL Audio Cleansweep and summing unit: You will use the summing unit
to combine all of the outputs from the stock amp into a full range signal,
then the cleansweep will apply eq and smooth the signal and provide
you pre-amp outputs to run to a set of aftermarket amps
3. Rockford Fosgate 3sixty.1 or .2: Same as above, except you now
have access to the adjustments via bluetooth pda or laptop
4. AudioControl LC6 or LC8: This is a unit which will sum your stock
amp outputs and give you pre-out signals for aftermarket amps. It
does not have equalization features or smoothing of the signal
that items 2 and 3 do, but it gets the job done.
There are many others, but I think you get the idea. Notice in the
above that I have not stated that you need to bypass your stock amp.
