21 - 22 of 22 Posts
Discussion Starter · #21 ·
When you say the "same issue" you must have proven the lights are solely related to the Steering Angle Sensor Initialisation problem and NOT just the warning lights appearing.
Many other faults would bring up these lights, so it is essential to check for error codes.
If your problems have occurred after a battery disconnect though and it is the Steering Angle Sensor that requires initialisation, just drive the car as normal and the lights should eventually disappear.
Jack
PROBLEM SOLVED. The C121A steering sensor gets loose over time, and all you need is a Torx screw to tighten it. IT FIXED MY PROBLEM.
Here's the video to prove it!!!
21 - 22 of 22 Posts
