Camber & Alignment question
4039 Views 4 Replies 5 Participants Last post by  Sosalove306
I posted this in the suspension area and got no responses, so I thought I would post it here. Any input would be appreciated....
I'm going through the inside of my right side tires and figure I have a camber problem. I'm getting ready to put all new rubber on, so I want to correct it now. Here are my specs
LF Camber -.3 Caster 10.1
RF Camber -.8 Caster 10.7
LR Camber -.6
RR Camber -1.1
Front toe and rear thrust are both correct.
So my plan is to put the camber bolt kit on the front right which should move it to -.5. And I suppose I will need to get a adjustable bushing for the rear. Napa has a .75 that should bring the rear back into place. Seems a cradle shift in not a good idea, cause it would move the camber issue to the other side and the left side is right on. I think all I need to do is address the one side.
My question is, if I do the camber bolt kit in the front right will I need to re align the front end, or will the toe change? Also has anyone done it and how difficult is it?
Same for the rear, how difficult is it to put the bushing in. Do you need any special tools, or can this be done in a garage and a weekend.
Also, and suggestions, i.e. should I use a bolt kit for the caster, or leave it alone. Running 255 45 20s stock height.
LR Camber -.6
RR Camber -1.1
tedodyssey i just did the same thing with my 300 touring and now i have the exact same problem u are having by any chance did u get the problem corrected and how can u please email me or anyone else that knows how to fix the pull to the right problem after u replace the tie rod end my email is [email protected] i have my wheels sitting at my house brand new and do not want to put the on until the problem is corrected.
yes i got the cradle shifted and allignment front and rear are on point! go to a good allignment shop like a good year.
http://www.300cforums.com/forums/su...-alignment-camber-kit-info-asap-please-4.html
Any time you touch the suspension like this, a wheel alignment is needed. How was your tire wearing, is it just the edge of the tire or the whole tire worn on an angle. If it is just the edge of the tire, it is the toe. If the caster was out too far, the car would pull to one side while driving.
For what it is worth, these are the settings I use on my 2006 SRT8. I find that my tire wear is good and very even using this set up.
More information is in this thread:
http://www.300cforums.com/forums/su...ifications/82969-bbii-getting-pedderized.html
Here are the alignment specs that Rob designed, knowing that I like to take my car onto the track:
Front Camber: -0.8 ; Front Caster: 9.6 ; Front Toe-in: 0.01; Steer-Ahead: 0.00
Rear Camber: -0.8 ; Rear Toe-in: 0.10; Thrust Angle: 0.06
How many camber bolts do I need for my 06 srt8
