Engine light came on so I did the ignition 'thingy' and the engine error code is
P 0420
Can anyone tell me what this means and how do I clear it?
Regards and thanks in advance.
Mark
P0420 = catalyst efficiency failure . only the stock pcm watches for the cat doing its job.
Disconnect neg. battery terminal for a minute or so.. then reconnect. Code goes bye, bye.
Dont know if this helps but found it on the srt8 forum!
use it!
P 0420
Mark
Mark,
Your Diablo tuner will easily read and interpret the codes for you, then clear them.
Thanks guys, I was about to clear it but it went off..so everything is good, thanks.
Mark
