1 - 8 of 8 Posts
Say you are interested in a wheel that does not come in the 115 bolt pattern.
What is involve in changing the bolt pattern?
Is that possible and what are the limitations.
I search the forums but did not find anything about changing the bolt pattern
Thanks,
-Richard
Yes you can. You can tapp them. That's how I got my 24" on my car when everyone else was charging an arm and a leg for 24". My rims were and still are only available in 5x120.65 and 5x127. I got them tapped from 120.65 to 115 with no problems at all. I had the only Charger on these wheels. Welcome to AKUZA.com
I had a machine shop that did it locally for me for $60. It involves using a bolt centric ring that they press into the original holes. There is more to it, but that's generally what they do.
topmotorsports. question - does tapping make a single drilled rim a dual drilled rim? If so does that mean you can only tap a rim that has lug bolt covers to cover up the dual drilled holes? thanks.
topmotorsports. question - does tapping make a single drilled rim a dual drilled rim? No it doesn't.
The only real set back is that the original bolt pattern you're going to tapp needs to be close to the 115 pattern.
1 - 8 of 8 Posts
