Hi all, can anyone help me ive recently had my 300c 2012 in garage for new alternator and since coming back the odometer is set to KM not miles....how do I change it back?? thanks in advance ::smile::
In my 2013 when the evic is on kmph just click right and it changes to mph. What are you seeing your fuel consumption, liters or gallons? There's a setting in the center screen settings function for litres/gallons
thanks ive managed to sort it out had to go into centre touch screen and settings to switch back to imperial....god knows why it had reverted to metric...possibly down to power failure so reset itself??
Do you mean the EVIC between the speedo and the rev counter? When did it go black?
I'm hoping you might just have turned it off - if that's the case the vehicle handbook says "Pressing any one of the four steering wheel buttons brings the menu back".
mid-day yesterday. I started car everything was normal. I turned my music down on left hand side of air con bezel, released the hand brake , and as I put it in reverse all the 8.4 screen went completely blank and my A/C is now stuck on defrost the full blast and it's not cold air. No response from touching the screen and I've checked all fuses and relays bit everything is in order.
Ah sorry thought you meant the EVIC not the Uconnect screen. Assuming since then you have had the car switched off the a period, usually that brings it back
Think you have several threads trying to answer the same problem
But ever since it happened my odometer is set to miles and my temp gauge set to Fahrenheit in the top section of the speedometer./evic
It should be set to kms and degrees Celsius I'm bloody Australian
