Hi Guys,
I have read a lot of threads about changing the rear diff of a 5.7 Ltr and thay talk about changing it to a 226 Getrag and axles.
With the US$ being what it is and our Govt's duty + gst it is becoming very expensive to do this convertion which has led me to stretch out for a little help from u guy's.
Will the late model 300's diff n axles assembly fit on2 the 2006 as it appears they r running Getrags 226 diffs and a more beefed up set of axles / hubs.
The p$ss off is they are only a 3.06 ratio but at the end of it i will get a better ratio than a 2.82 and LSD it its possible.
Thx 4 reading
AL
Yes they will bolt up no problem and the 3.06 ratio is a great ratio with some of the quickest running cars... While a deeper gear will get you out of the hole, as hp increases it will also spin the tires like they are donuts.
Picking a ratio is more about knowing what your mods are and where you want to end up... I always wanted a 3.55, then I supercharged her and I couldn't imagine having anything that short, it would just be smoke at every turn!
You need pumpkin, axles, hubs and rear section of driveshaft.
Reactions: Jim777
Hi Silver,
Thanks for the reply and we have a holiday coming up which i thought would be a good time to do the swap.
But i think i am reading to many posts on this subject and getting a little confused so if you don't mind do you know if i need
getrag upper pinion mount....getrag lower pinion mount ??
I have the following,
3.06 Getrag
Mounting Bolt
LH Axle Shaft
RH Axle Shaft
Axle Shaft Nuts
Axle Hubs
Going to get a 392 Getrag Coupler.
Thanks for your help
AL
Yeah done my 06 C sometime back, you say late model how late are you talking about?
Thnx 4 replying Typan,
I believe its a Getrag out of a 2012 or 2014 Chrysler 300 SRT8, 6.4
Cheer
AL
If your changing out the hole diff assembly you may find that your 2006 C drive flange is a 3 bolt type & the 2012 is a 4 bolt type and the 2012 housing is larger which you have to change out the drive axles too, it's a lot of work but yeah it can be done mate. I fitted a wavetrac center, now that's a diff center Wavetrac® Differential - A torque biasing differential with a difference have a look.
Thanks Typan,
A little worried but i suppose i cant go back now.
Cheers
AL
