1 - 3 of 3 Posts
Tengo código p0481 los realey se cambiaron. No es el problema los abanicos prenden en 226 high .tengo burbujeo en el tanque que puede ser ayuda
2014 CRD
Sorry my Spanish isn't good. I think you're saying you have code p0481 which is the high speed fan circuit and have already replaced the relay and that the fans don't turn on until 226 degrees - which is too high
There's a thread here Link which has a circuit outline, hope that helps. I would check the integrity of the wiring and the earth in case that's a problem. It can be the FCM at fault too I believe
1 - 3 of 3 Posts
