My cig lighter is not working (front one) not the one in the center consol does. Is there a fuse might be blown? Which is the fuse to check any1?? Thanks...Chris. Or could it be the lighter thing you plug in?any info will help
Check to see if it operates with the key in the on position. Thats the only way mine works. One inside the console is powered all the time. Other that that, the first thing to do is check the fuse.
Fuse 18 in the trunk , has 2 positions constant power or key switched power.
