1 - 17 of 17 Posts
recently my cigarette lighter does not work anymore, i check my manual for which fuse it was and there was no fuse in that spot but the lighter did work couple weeks ago, and it seems like my whole fuse box is mixed up, nothing is where it should be. any help would be appreciated
Here's the list of fuses and their locations. You should be looking for fuse #18 (20 amp yellow) in the Rear Power Distribution Center. It's marked as "Selectable Power Outlet" in the manual.
Bernie
do you use the lighter regularly,if so you could have burnt the element out,I see it regularly at my shop.Its because you actually touch your cigarette onto the element and you really shouldnt,it will light purely off the heat off the element
Someone is telling you to give up smoking!!!!
Reactions: NoeMireles
my cigarette lighter is actually stuck.. i cant pull it out anymore..
i think i got the wrong one because i lost mine so they gave me a new one out of an 08 srt design at the dealership (i drive an 05 C).
Discussion Starter · #6 ·
fixed, i checked my fuse box again, and the guy who installed my subwoofer put the rem wire into the fuse for the lighter so i moved it and it works now thanks for your help guys.
I switched out the fuse #18 with a new one and the lighter still doesn't supply power to my phone charger. Any other things that could cause this? Thanks for your help fellas.
You should use the power in-put, in the center console for any thing that you want to power. It looks just like the lighter input with a cap on it.
Now the cigerette lighter will give power but only when the key is in the on position. Is this the norm since my cigerette power source never worked I am not sure.
I believe this is normal.
Thanks Bailman for the confirmation. I also read on other threads that it is because the power source in the console is directly wired to the car's battery therefore provides power continously regardless if the car is on or not. However the ashtray power source is on a different circuit so when the key is not in the "on" position no power goes to that outlet.
In my center console, the auxiliary 12v plug (Inside the console, not the one inside the ashtray) is not working. Can anyone tell me where this fuse is located as I have no other electrical issues at this time. Thanks so much!
The cigarette lighter works just fine in the ashtray but the one I use to charge my cell phone is no longer working.
Just looking for the fuse location!
Thanks so much guys!
Neither power outlet working - both fuses good
My problem is both outlets are not working but both fuses are good. I checked them with a volt meter on both sides.
Any help would be greatly appreciated.
Bernie
Thanks also Bernie, my Cig lighter has been out for months now, been meaning to fix that. Thanks for the attachment and I will scoop out what fuses have been at fault.
I'm not really a smoker... I just can't stand it when even a small thing is wrong with my car.
Thanks again!
here's something strange. My cig lighter stoppped working a while ago. Jet now my power supply works either. Fuses are good. checked the wiring. seems ok. any ideas? -05 300c v6
fuse # 18 has two positions ign. controlled and always hot see what position its in also check cavity #30 relay at the (RPDC)
Both of my car/ cig slots stopped working when I last had a charger plugged in I took it out and the whole bottom of the charger fell out .. since then the both of the slots don’t work and I am not sure what fuses to check xx I know the numbers just not the exact fuse .. help ! Please
1 - 17 of 17 Posts
