1 - 2 of 2 Posts
Any suggestions on how to clean the inside of the windscreen washer bottle?
Mine has gone a bit black around the visible top part.
Thanks
Once you have it out, you can clean it the same way as the coolant reservoir; some automatic dishwashing detergent, hot water, and a brush if necessary. Unfortunately, removing it from the car is a fairly big job.
It's easier to remove the front splash guard (not the engine splash guard) and/or pop the fender liner loose, and disconnect the hose, and temporarily replace it with a hose feeding into an old bucket. Then use the same methods as above, and flush very carefully and thoroughly when done.
1 - 2 of 2 Posts
