Hello again everyone,
:repost: :feedback:
I originally posted inside another thread in General Discussion about A/C behavior, but I thought I would present it here as I need some feedback from other drivers. Please let me know if this behavior is expected/acceptable, or if I should press the dealership for some warranty work.
I have observed some odd behavior with my 2006 300C climate control:
In manual mode, when selecting a relatively high temperature, only cool air comes out of the front facing vents. Only when selecting max heat (red dot) will any heat come from these front vents (at which point it is an extreme ammount of heat).
Further investigation shows that if different air flow is selected (i.e. floor or defrost vents), the amount of heat being produced from those vents is consistent with the relative temperature setting. An interesting finding was that when I changed the air flow from defrost vents to the front vents, the air went from a correct, warm temperature through the defrost vents, to a very cold temperature through the front vents.
I have gone to my dealership about this issue, but they were not able to address it at that time (I had not done the last part of the testing yet - I will return with this update).
One last behavior that I have observed and I would like to know if anyone else has:
When using automatic mode on the climate control and changing to manual mode, the A/C light always comes on. I am assuming that this is because the climate control has automatically engaged the A/C. Should this be happenning even when I am trying to heat the interior up in automatic mode? Again, throughout this process, cold air is coming through the front vents.
Please reply with any information so that I can return to the dealership armed with more information.
Thank you ... Greg
:newbie:
:repost: :feedback:
Thank you ... Greg
:newbie:
