1 - 19 of 19 Posts
The Cold Weather Package came with my 300C and guess what, it's cold here in New England. So have been plugging in at night, which should benefit the engine over time. Actually my fully loaded C has been a bargain as I have used all the features extensivily, except the smokers group. Who would have thunk it.
Heats up Engine
coolvanilla said:
I too have the CWP. On the way home from work I thought I should plug it in tonight when I get home. Of course I forgot and I'm too warm & comfy to go out and do it now. What exactly does it heat anyway?
The CWP is the engine block heater. With that said it warms up your engine! I don't blame you for staying in and keeping warm :) . Take care :)
Cold Weather package
My power cord lays on the drivers side of the engine and tucks behind the black box there. I just route it out under the hood on top of the grill, it doesn't interfer with closing the hood. My experience with CWP is that you get the engine nice and warm first then plug it in. It is just a chunck of metal, attached to the engine block, with a cal rod inside and it gets warm. Nothing sophisticated here, old time technology, I would think.
I can't bring myself to slam the hood shut with a power cord hanging out. Sounds a little risky! There has to be a better way.
coolvanilla said:
Do you mean fish it on the drivers side headlight through the hood, on the side fender, by the windshield, or dropped directly to the ground?
Thanks!
OK, maybe I wasn't clear enough and I'm sorry for that. All you have to do is open the hood pull out the cord which will be above the headlight but to the left of it as you are facing the car, this is on the drivers side on my car. There is a bit of a trough at this point. The hood will not come in contact with the cord as you can push it back and forth without it binding on anything. The cord will now dangle (About 3-4 inches) to the left of the center grill and to right of the headlight. When the weather is warmer and you don't need it then put it back under the hood. I hope I am clear on this.
coolvanilla said:
jjs
I prefer your solution to the engine block heater :)
Did that myself over 15 years ago and have not regretted it...first 25 years of life stuck in Cleveland (east side...you Great Lakers know what I mean by 'just starting the snow belt'). Couple years in FL, now in TX... ;)
coolvanilla said:
When I started the car a couple of hours ago after sitting in the parking lot all day in single digit temps the engine temp read 28 degrees. Was up to 210 by the time I got home (30 mins).
After much assistance (thanks Mikeyjohn) I plugged my engine block heater in last night. After 12 hours or more in zero degree temp the engine temp now read 86 degrees (compared to 28). The oil psi is 49 compared to 55 yesterday.
i notice that since i had the cpu flashed to 3.5 sumpin. i dont see my oil pressure readout anymore.??
1 - 19 of 19 Posts
