Hello,
I have a CHRYSLER 300C , 2007 Model with 55,000 miles . About 2 weeks ago the Electronic clutch control light and Engine block light both came on and would not clear whilst driving. I took it in to my local garage and was told that the Swirl Port Motor needs replacing and would cost me GBP 570.00 + Labour GBP 450.00 + VAT , so costly.
The thing is I love this car, and I am getting it fixed, but is this problem likely to occur again or do I need to sell.
I have seen on other sites that this is a regular occurrence .I do not have any error codes.
Regards,
Colin
There is a cheaper alternative - Chrysler 300c Swirl Port Emulator . Plug it in, leave the broken swirl in situ and drive happily ever after. Passes MOTs and runs fine.
If you are getting it fixed, however, there's a seal that needs replacing in the pipe that drips onto the swirl. Check the many swirl related threads on here for details.
Dear talldave,
Thank you for your advise, so I can just leave it where it is. I will contact the garage, hopefully they have not started the work. If they have I will mention that they have to replace the pipe that drips into the swirl.
Thanks again.
Regards,
Colin
Hello,
How did you check for error codes? If the swirl motor had failed and/or you had warning lights, then there should have been error codes set. Did your engine go into "limp" mode? Hopefully, you will be able to avoid the expense of a new swirl motor by following talldave's advice.
Replacing the turbo inlet pipe is not cheap either.
I made the mistake of having mine changed at the dealership a few years ago. AND they replaced it with the same (orange) seal. There is a site where you can buy just the seal (black) that does not drip, saving you at least £150.00!
Or, you follow the advice and bypass the swirl motor.
Hi ,
I had the warning lights come on for Electronic Clutch Control & Engine Light stayed on, my car drove ok though, but booked it in to the local garage , very costly GBP 1300.00 all in , still at garage.
Thanks & regards,
Just to echo the above points on the swirl emulator that can be bought from the 300C Custom Shop.
I had a similar issue four months ago after only owning the car for a few weeks. My local garage said they would need a couple of hours to strip down, to investigate, even before they could let me know what needed fixing.
I decided to research myself and thanks to this excellent forum and with the help from the 300C Custom Shop, I bought the swirl emulator for £40, fitted myself in about 30 mins and everything now works perfectly.
I was very happy!!!
Such a great car, makes me smile every time I get in it!!!
I was very happy!!!
Hi AB77,
Wow GBP 40.00 for a swirl emulator, in future I will get my stuff from the 300C Custom shop, mind you I have no clue on to fit it, but still, I will get a Mechanic to fit it.
Cheers,
Colin
Hi AB77,
Cheers,
Colin
The pictures you need are in post 30 from Paul at the custom300cshop here: Link
Hi AB77,
Cheers,
Colin
Its so easy to fit yourself. Id never done more on an engine than check the oil before and I managed it no trouble. From what I remember you remove engine cover, undo jubilee clip from the pipe to the port, lift it up, unplug something and plug in the emulator. Theres a guide somewhere. Took me 20 minutes and most of that time was because I was pussy footing around sh*tting myself!
