The following is quoted from the November, 2004 issue of "Consumer Reports":
First look: Chrysler 300 (a pic of the Touring accompanies the article)
Of the new models introduced for 2005, the Chrysler 300 has been one of the most talked about. Our initial impressions of two versions we've bought for testing are that they are pleasant to drive, with roomy quiet cabins. Helped by a rear-suspension that's modeled after that of the Mercedes-Benz E-Class luxury sedan, the 300's handling is sound, though not sporty, and the ride is firm, yet not uncomfortable. Overall, the interior quality is a significant upgrade for Chrysler, but there are some drawbacks that detract from the car's appeal.
The boldly styled 300 and its wagon counterpart, the Dodge Magnum -- both large, rear-wheel-drive cars with prominent grilles and a sharp-edged design -- represent a new direction for Chrysler's cars. By contrast, Chrysler's trademark since the early '90's has been sleeker, front-wheel-drive, cab-forward models.
The 300 line includes four trim levels: the base 300, 300 Touring, 300 Limited, and top-of-the-line 300C. For testing, we bought both the well-equipped 300C ($36,685) and the Touring model ($29,775).
To aid the snow traction and handling stability of this rear-wheel-drive car, optional traction control and electronic stability control (ESC) systems are commonly available, except on the base model. All-wheel drive will be available later.
The 300C features Chrysler's 340-hp, 5.7-liter Hemi V8, which gives the car a strong, muscular feel. The Hemi name is more nostalgic than technically significant. First used in the mid-1960s, it refers to hemispherical or dome-shaped combustion chambers, a common design.
To help improve gas mileage, the big V8 is equipped with a system that shuts off half of the engine's cylinders when the car is cruising at a steady highway speed. All cylinders are instantly activated when more power is needed for acceleration or climbing a grade. We've found the transition between eight and four cylinders smooth and mostly imperceptible. A similar variable-displacement system has been introduced in some GM pickups, and another will be used in the upcoming Honda Accord Hybrid sedan.
The cabin is roomy but the high window line, shallow windshield, and large rear roof pillars reduce visibility. Drivers may have to duck to see overhead traffic lights. Some flimsy door-trim materials and suspension noise also also detract from the luxurious driving experience.
Other complaints so far focus on the relatively small trunk, the lack of assist grips over the front doors, and wiper-and-cruise-control stalks, identical to those used in Mercedes cars, that are unintuitive and inconvenient to operate.
The 300 Touring version utilizes the 250-hp, 3.5-liter engine that was used in the front-wheel-drive Chrysler Condorde and Dodge Intrepid. But the engine is quieter in the 300. The Touring isn't as quick or lavishly equipped as the 300C.
We'll tell you how both the 300C and the Touring model rank against the competition when we publish the full test reports in an upcoming issue."
