Just like it says wondering what the average cost per tire is on those 20's. I know it verys alot depending on performance....ect but would like a rough ballpark estimate on how much it would for tires on these guys.
They fit the stock 20's, front & rear, I assume?I just bought Toyo Proxes 4 (255/45/20 for the front and 275/40/20 for the rears). With shipping, they cost me about $720. Plan ahead, I had a hard time finding the 255's - plenty of 275's around. 255's are on a ship between Japan and here - ETA 30 days if all goes well.
-david
Yes, they fit fine. I haven't seen any rubbing so far.They fit the stock 20's, front & rear, I assume?
LJB![]()
How's the Ride Quality? Are they quiet? Take road imperfections ok?Yes, they fit fine. I haven't seen any rubbing so far.
I take it those are "ZR" Toyos?Do you want the front tires to be taller than the rear ones???? WHY?
Use 275 all around or use 245/45/20 front for near perfect match. Your tire guy should have told you this. None of the 3 sizes rub on any SRT8 with stock rims. Remember your gearing is very slightly better with a shorter tire.
245/45/20 is 28.68 inches high
255/45/20 is 29.03
275/40/20 is 28.66
Now, the Toyo Proxes plus 4 is a great compromise tire. Fairly quiet, rides well, and wears like iron. They give up a very small amount of summer performance to give you true 4 season capability. They are the best all season tire I have ever owned, they really stick great in almost any weather.
When you factor in how CHEAP they are, it's easy to like them. And they are designed for the proper weight, not for a fat SUV!
I was curious. Why didn't you go for a 255/45/ZR20 for the rears, which is an exact size replacement for stock?Do you want the front tires to be taller than the rear ones???? WHY?
255/45/20 is 29.03
275/40/20 is 28.66
My car came stock with 245/45/20 all around. Lots of SRT8's did.I was curious. Why didn't you go for a 255/45/ZR20 for the rears, which is an exact size replacement for stock?
LJB![]()
Crap. I started this out with a very strong recollection of seeing posts about running 255/275's when I first joined the forum a year ago. I used the tire calculator - and somehow I still screwed this up. So now I've got tires on the front that are about 3/8" taller than the back, with sidewalls that are about 3/16" taller. Its interesting that none of the C2M2 guys seem to have noticed so far. I just made a couple of trips out to the garage for some good long looks. I think its tough to see it and the car as a whole still has a noticeable forward rake. Other than the appearance issue, does anybody believe this diff will have any effect on the car?Do you want the front tires to be taller than the rear ones???? WHY?
255/45/20 is 29.03
275/40/20 is 28.66
Stop beating yourself up, everybody screws up sometimes. But your tire guys should have mentioned it to you.somehow I still screwed this up. So now I've got tires on the front that are about 3/8" taller than the back, with sidewalls that are about 3/16" taller.
I've noticed a tendency to flat-spot. It works its way out within 3-4 miles, but its a little irritating.
