1 - 2 of 2 Posts
Hi all, can someone help with any idea?
Front right tpms doesnt work. What I have tried? Everything from posts :).
Additional:
1. Changed 3 tpms, 2 works (rear ones), front right doesnt work. Tried 3 diiferent valves on that front right...not oem, still no luck.
2. Changed one transponder on FR...still no luck.
I have changed 2x rear and copy codes from old tpms to new ones and all good.
I have changed 3 different valves on that front right but i have add new code to tpms valve, because original one was dead. We have added code from manufacturer of valve for car model (300c, 2006....crd...).
I think this is not problem. As i remember i already done this before on one wheel and works for couple of years...but im not 100% sure (copied or new code on valve).
Maybe we have copied code from old one valve.
Any idea will be great!
And another test/try, pull out both transponders....front left and front right. Left tire is VISIBLE?!?! and right still blank...wtf?!?! Pull out battery...same...
Do i need to do something with obd? Scantool or something else?
Thanks all.
Discussion Starter · #2 ·
Fixed! You need to copy your old codes, from working tpms to new one. You cannot use any other code....or you must write in car new codes (i presume with obd or something)
1 - 2 of 2 Posts
