My car threw a check engine light. I checked it and it said "cylinder 8 misfire". Any ideas??
spark plug may be bad. take it to dealer if under warranty, otherwise, replace the cylinder 8 plug.
first take it to dealer if it's under warranty and let them fix it.
otherwise i would start with replacing the spark plug for cylinder 8 and see if that fixes the problem.
Bump>>>>>>>>>>>\
Maybe check the gap or wires..........
yeah check it.
may not be on tight enough.
after that, ?
i am not a mechanic
are you stock?
I have an air intake, predator, and exhaust. I will check the gap and make sure it is correct. Thanks for all the input!!
