Well, its plumbed in and programmed, the evic comes alive in 5 second after pressing 3X close button on the fob as it attempts to start, so something is happening....however
.....the starter will not turning, either because of the immobiliser or the ignition (+) output not connected.
I have a pink wire from the loom within the bundle, however its suppose to join to the ignition (+) output and I assume this was albeit connected up within T connector plug & play outfit.
Its not as straight forward as made out or claimed by a few and I will confirm this as soon as I find out, so those who would like one, PLEASE hold off for now and save your expense.
In the meantime could some kind soul confirm or check for me from the Chrysler schematics and if you could indicate which is the ignition (+) output and also post the SKEEM connectors output.
(ps yellow/black is successfully connected to the purple, which is the door pin)
