my question is on the diablo if it matters if i put my tire size or not?? or why does it ask for the tire size???
nope it doesn't matter unless you changed to a bigger rim..what it does for you is recalibrate so your speedo is correct
If you have changed the tire size by using the Plus method then yes it does matter. See besides the speedo it also affects your gear changes ;)
I personally feel that the diablo defaults to a 250/60/20. If you go into the tire size menu that is what each setting is at. It will screw up your odometer and make it seem you're going faster than you are.
