1 - 11 of 11 Posts
I saw a picture recently of a digital voltmeter where the factory analog clock goes above the stereo. Does anyone know where I can get something like this done? Is this a part that I can buy or is this a custom job? I think it's a great idea for a stereo system.
The picture attached I believe is a pressure gauge for air suspension, but this is the idea I'm going for.
Anything else on this. I'm trying to fit a Aeroforce gauge in the clock position and need some info on what needs to be done to fit!
You want it to look like my hotness....
I just took my gauge, held it in the opening, and used my ghetto harbor freight "rotary tool" to enlarge the hole enought to fit the gauge. Worked like a charm and it looks factory.
What did you use to hold the gauge in place??
the dakota digital has a c shaped piece that has threaded posts in the back like most gauges do for mounting them directly in panels.
i give this a 2 out of 10 on the hardness scale. You could probably complete this task with a butter knife and some determination if you really wanted to.
that gauge reads my pressure at each corner of my car for my air suspension.
It also reads tank pressure when I hit the button on it.
Air pressure basically determines ride height and can be adjusted on the fly.
1 - 11 of 11 Posts
