Last night, after again wondering why that 10" sub sounded so weak, I decided to do some testing. I first listened to a song with some low bass for reference. I then disconnected the sub in the trunk, to see get an idea of how much bass the sub actually contributed. (I owned a 300C previous to this, and the Boston system WITHOUT the sub actually sounded better IMO.) Not to my surprise, the Kicker system produced MORE low end response through the 6x9's in the door than with the sub playing.
Having a background in mobile electronics, I knew that this was due to something very simple...sound cancellation. The subwoofer was playing 180 degrees out of phase with the 6x9's in the door, so they were actually working AGAINST each other, and effectively cancelling out the low end frequencies.
To remedy this, I simply removed the sub from the enclosure and swapped the positive and negative connections at the sub. Luckily, on this sub, the two terminals are the same size. This made a HUGE difference. I can now hear and feel the bass, without opening up the back seats.
The question is, was this sub simply hooked up wrong from the factory on my car, or are the kicker systems designed in such a way that the sub, due to its location, operate out of phase with the rest of the system. You other guys with car audio background know that some aftermarket sub amps actually have a switch to change the phase from 0 to 180 degrees for this exact reason.
Anyway, the point is my sub sounds WAY better, and I can now say that I am happy with the Kicker system. Bye the way, I also removed the center channel to correct the front stage/imaging problem.
