I finally made a ram air duct for my car using a few threads from this forum as my starting point.
First I took a 4" rigid aluminum dryer vent:
Then I took a 4" PVC thread adapter:
With a little work I inserted the thread adapter into one end of the 4" duct and secured it with a bandclamp.
Then I removed the airbox, the two plastic shields below the engine compartment as well as the front portion of the driver-side brake duct.
Next I inserted the threaded end of my duct into the bottom side of the airbox and secured it with a 4" metal threaded ring as follows:
I then cut off about 8 to 10 inches from the other end and curved the 4" vent towards the bumper vent.
After fitting it perfectly I removed it and spray-painted it with flat-black, quick-drying paint.
Here's what it looks like after putting everything back together:
The paint scraped off of the end as I secured it with a zip tie so I put a couple pieces of electrical tape to hide the shine parts and prevent further scraping from daily driving.
Here's what it looks like from a distance:
It's pretty hard to see unless you're looking for it and walk up close.
It does feel stronger but I don't have numbers to back it up. I'm hoping to do some tests with my GTechPro Comp. soon.
chiro444 said:
Very nice job!!:fing02: Did the brake duct stay off or did it get re-installed?
The front portion of the driver-side brake duct was removed to make room for the 4" vent hose. The rear portion remained intact after completion.
Lots of DIYers have taken this approach and yours looks as good as any of them. However, if I were to do this I would duct to the upper sides of the central radiator by removing one of the upper baffles. I wouldn't/don't want to take any chances with water induction from large puddles, or the like.
Just my two cents...
