1 - 20 of 53 Posts
I thought I'd give 87 a whirl, save a dime a gallon :banana: . Comming up my big hill today it began to ping!!! :eek:uch: Last time for this boneheaded maneuver. My X5 required 93 and I used 87 all the time with no issues at all which is why I was willing to try 2 points lower in the C, boy was I wrong.
Humm I was 87 about 1/2 the time I have always had good luck with it and could not tell of any power loss or MPG loss.
· Premium Member
He was referring to detonation (not a good thing at all for an engine), not any kind of loss.
Kings, if you're pinging, I would definitley not let this tank run it's course. Get 93 in there as soon as there is space to try to balance it out. If there is a way to do it on these cars (I don't know much about these fancy pantsy cars and their com-pu-ters) you might want to set the mixture rich.
Richard
Really????
I thought I had read somewhere on these forums that 87 was just fine, and that there were no adverse affects. I have used 87 the entire 3400 miles, and she runs great. I did read in the oweners manual that 89 is recommended, but 87 will work fine. It said that premium was NOT recommended, which suprised me.
I have used 87 about 40% of the time in my 3 months and 2500 miles. It has worked fine. Wonder if it could be something else or maybe just a bad tank of gas.
DCX knows what they're doing. That's why they chose an octane that will work for all. With all the variables involved with vehicle octane requirements, 89 is the safe, and conservative compromise for all. This is not to say that lower octanes can't, or should not be used. That is why they use the terminology, "recommended". Those that live in cooler climates may be able to use a lower octane fuel in the winter. (See last reference). Owners that live at altitude do not need, nor require the higher octane (a waste of money), as stated in the following references:
Gasoline Digest, "In high-altitude areas, you’ll find lower octane gas. “Pressure and temperature in the combustion chamber are less at altitude.” Wusz stated.
Gasoline FAQ, "On modern engines with sophisticated engine management systems, the engine can operate efficiently on fuels of a wider range of octane rating, but there remains an optimum octane for the engine under specific driving conditions."
"Once you have identified the fuel that keeps the engine at optimum settings,
there is no advantage in moving to an even higher octane fuel. The manufacturer's recommendation is conservative, so you may be able to carefully reduce the fuel octane."
"If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away."
"You may be able to change octanes between seasons ( reduce
octane in winter ) to obtain the most cost-effective fuel without loss of
driveability."
So, not everyone needs, nor should necessarily use 89 octane fuel. As stated in the references, find the one that works best for you, in your environment and climate, and go with it. Some may be able to change octanes from summer to winter. Personally, I've used 87 almost since I got my Magnum RT, and although the per tank savings is not that much, figure the savings over 15000-30000 miles at today's prices, and the savings are no longer pennys. Using 91 or 93 anywhere would definitely be a waste of money. Also, those who must use reformulated or oxygenated fuels will probably see lower performance and lower mileage.
Hi,
I live on a hill, just over 150 ft above sea level. I have been using 87 octane for the last couple of months. I have not had any pinging, nor have I noticed any power or fuel economy loss.
I would suspect bad gas as the culprit. I had a situation a few years back with my 1998 T&C. I filled up in Orange County and returned home over the Ortega Hwy, which is a winding mountain road. On the way home, the van started pinging and over heating. When I got home i drained and flushed the radiator, but it was very clean. The problems continued until I got down to about 1/2 tank, when I added 91 octane to fill the tank. The pinging and overheating immediately went away. I never had the problem again, even with 87 octane, so I believe I got a bath of bad gas. This may have been the problem.
Phil
87 since I got it. I'm guessing a bad batch of fuel. That unfortunately can be a hit or miss problem.
Discussion Starter · #15 ·
Bad gas is possible, maybe I should put some injector cleaner in the tank. Adding 93 is a good idea but I'm past the full mark.
The base of my hill is 700ft above sea level and over 3/4 mile it rises to just over 1000ft. and the majority of the rise is in the last 1/4 mile, it gets pretty steep.
I can get gas at two stations for only a nickle more per grade, really not worth it for 15 -16 nickles/tank even over 30K miles or more. The cost of my grille or intake would cover a lifetime of nickles.
Well bad gas or whatever, if you're pinging, don't run it hard until you get some other gas in there. An engine that pings is an engine that could (I'm not saying will, but could) hole a piston or burn a cylinder or various other issue with being too hot in the combustion chamber.
Discussion Starter · #17 ·
Yes, granny driving is the order of the day, hmmm, bad gas, I ran 87 in the Bimmer a full 6 points lower than recommended and never had a problem. Ironic that the first time I run 87 in the C I get a batch of "bad gas", what are the odds of that happening. Bad gas or not, for this car I am using 89 only. Oh, btw, never had a batch of bad 89 in almost 12K miles, irony can be so ironic sometimes.
We use 87 about 1/2 time along with 89 the balance. no issues to date, no pinging during our really hot weather. Don't see any issues, fuel is typically ARCO, Chevron or Costco.
Which leads me to think what I've always thought: for this engine 87 is just on the edge of the knock sensors retarding of timing and richening of fuel (BMW's that go to the US get knock sensors with a lot of leeway...BMW thinks VERY poorly of our gas). Many users have no problem because the knock sensor is taking care of it, and most likely people who use 87 to save a bit are not the same people who are going to spend a lot of time with the pedal to the floor and noticing a slight loss of power. I for one noticed a very slight ping in a Silverado I had for a little while when runnng 87 even though the manual said 87 was ok, but not ideal.
I suggest adding 4-6 ounces of Acetone to straighten out this bad tank of gas.
It is supposed to raise the octane a bit and increase the fuel milage 20-30 percent in some cases. :)
1 - 20 of 53 Posts
