05HemiC said:
Has anyone heard of these guys?
I understand these aren't going to compete with the Brembo's of the world, but they are a hell of a lot cheaper and wondered if they would be a good mild upgrade?
Has anyone heard of this company?
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7952641014&category=33564
R1 Concepts either doesn't know much about brake performance or they are being deceptive in their advertising. Let's review some of their eBay ad claims about the
"Advantages of Cross-drilled and Slotted Rotors":
-Maximum air circulation for increased cooling
False. The air circulation is a function of the internal vane design and has nothing to do with slots or drilled holes. The rotor acts as a pump using internal vanes to move air from the hub, in between the two friction surfaces, to the outer edge. Slotting has no effect on airflow through the middle. And drilling holes also has no effect. If you are an air molecule in the process of being pumped from the inner to the outer edge, do you think you would suddenly stop and take a 90 degree turn, just because you saw a hole to your right? It just doesn't work that way. Drilling and slotting do not affect airflow through the inside of the rotor.
-Improved wet weather braking
True. Slotting or drilling will improve initial bite in wet weather conditions.
-Mill balanced to prevent vibration
Not relevant to the discussion of slotting and drilling. Most rotors are balanced during manufacturing. This is a good thing, but it's not a feature of drilling or slotting.
-Zinc Plated for protection against rusting
False because these rotors are not plated. Zinc plating does protect the unswept areas of a rotor from rust. And the ad claims in several places that these rotors are plated. But the eBay ad also says:
"PREMUIMS ONLY COMES WITH BLACK ELECTRIC COATING ON THE HUB, EDGES, AND VENTS OF THE ROTORS TO HELP IT FROM RUSTING. BASE AREA OF THE ROTORS ARE SILVER. SO NO ZINC PLATING CAN BE DONE TO THESE HIGH PERFORMANCE ROTORS." So the advertisement has internal inconsistencies. They are cutting and pasting boilerplate material.
-Increased brake pad bite
True. Drilling or slotting are both done to increase bite.
-Cooler brakes Pad
Sort of true. The escape path for the gasses does allow the surface of the pads to run slightly cooler. Note the improper grammar. Another hint these are Asian parts.
-Promote longer rotor and pad life
False - Part 1: Drilled or slotted rotors will wear away your brake pads sooner than plain rotors. Think about the analogy of a cheese grater!
False - Part 2: On the street, drilled or slotted rotors should last nearly as long as plain rotors. At the track, all types of rotors (plain, slotted, drilled) will develop surface micro cracks which will eventually grow until the rotor fails or is replaced. But drilled rotors do this faster than plain or slotted.
While Brembo, Zimmerman, ATE, Balo, Powerslot and other quality manufacturers do not yet make replacement rotors for the 300C, replacement Brembo rotors for the 300M are only $50 each at Tire Rack. Powerslot rotors (slotted obviously) are available for $95 each.
Eventually the legitimate aftermarket rotor manufacturers will offer a range of products for the 300C. And when Brembo drilled
or slotted rotors become available, they won't be much more expensive than these eBay rotors.
