My drivers side review mirror is all fogged out,
its has the Autodim, my question, is it possible to just replace only the mirror glass and not the enitre unit?
found this site OEMDodgeParts.com
looks like I can just buy the glass, anyone try this?
dont care about Autodim, anyone have a pdf of how?
2005 300c all options
yes you can just replace the glass. if you push the mirror glass all the way to one side and look into the gap youll see the assembly is held on by a number of clips, probably around 6-8 in total. just pry those up with a screwdriver (you may need more than one to do it as youll want to keep one open while you pry up another). Once the tension is removed the glass will pop off. If you have autodim, there will be a couple of wires at the bottom youll need to pull off of their connectors. The new mirror glass will just push snap in place. Difficulty level 2, time needed 15mins.
yea my mirrow did the same thing and I just replaced it. Had my mechanic do it while it was in for other things. Just the glass cost like $150 though as I recall. One dealer wanted $175 for it. It had gotten all tarnished looking and hard to see things - wierd.
Bob
