2005 new body style Chrysler 300. Under driver side dash next next to emergency brake there is a square hole with a black patch. Same on passenger side. Why is there a hole here? There is a black patch and if you rip it off there's foam underneath. There's water coming from here when pouring on the black plastic windshield drain. Bottom part of foam is wet. If I seal this up then water will build up here...? It makes no sense if it was normal to have water go through there that there would be foam. Has anyone had a leak from here? What is the solution?
