I have not noticed any posts about adding DVD capabilities to the 300C. Here is what I came up with. I wanted to keep all the features that come with the stock head unit (Nav, CD changer, Bluetooth, steering wheel controls, etc) and use then at the same time as video, but I also wanted DVD, so instead of removing the OEM deck and replacing it, I added a flip down Sony unit. This is their Dream System which consists of a seperate DVD player and flipdown unit (only $700 at Goodguys). It has very good quality video. I used this unit because the flipdown is small and I felt it would fit in the stock Sunroof/overhead light/sunglass holder area. I removed the stock overhead light setup as a unit (it snaps into place) and had to trim the plastic support bracketry under the headliner some. I also had to fab up a mounting bracket, very easy. I have not got around to relocating the Sunroof or garage door opener switches yet. The neat part is that the stock opening in the headliner is unmolested. The DVD player is mounted to the bottom of the package tray (pointing forward) so it can be accessed inside the car by lowering the seat back. For back seat viewing I added a seperate Pioneer unit to a canabilized mount I had left over from a previous I.C.E. install. It mounts to the pillar just behind the passengers head. The audio comes from an F.M. Modulator (until someone comes up with a hardwire fix), and the Sony unit also comes with wireless headphones that read IR from the flipdown unit. The remote sends IR control info the the flipdown unit so direct line of sight is not needed for the DVD player. There are additional headphone jacks in the Sony breakout box (where all the connections are made). So let me know what you think and if you have any questions I will try to answer them.
