I have a question regarding the eibach pro kit spring installation. A buddy and I installed a pro kit on my 300C this weekend and while the front turned out fine, the rear didn't drop but about a half-inch. Eibach suggests cutting 25mm off the rear bump stops which we didn't do (which leads me to believe that's where we went wrong) as I'm not sure where they are. Are they at the top of spring or inside rear damper?
To anyone who has installed a set, could you please advise as to what you cut, and how you cut. I'm not sure if that is the reason it didn't drop as it does not seem to be sitting on the bump stops now. Any ideas would be appreciated.Thanks!
