Its starting to get a little cold here in Maryland (sorry everyone from the NW and Canada), and recently the gadgetry that controls the car is going haywire. The problem is that none of the gauge dials respond on start up, and the automatic starter does not work. I get the horn beep, and the internal electronics turn on, but then it beeps three times, and does not even turn over. The gauges not working is also joined by the "ESP BAS" warning light, as well as the "Check Engine" light.
I mention the temperature, because as the car warms up, and I have driven a while, the gauges will all of a sudden respond and read actual temp, rpm, speed, fuel...and usually the check engine light goes off soon after. All the EVIC indications are correct, and I use these to know what the hell is going on until the gauges start to work. I check every single breaker and fuse, fore and aft, and they are all good and tight.
I went by the dealership twice. Once when i didnt realize it had something to do with how long she has been sitting around (in the garage of course), and the car responded normally. After two more days of this happening I left it overnight and they saw what I saw. They are saying the computer spit out about 40 error codes, and seems to be arguing with itself over what is really the matter. They sent the diagnostics off to STAR at Chrysler, and are awaiting an answer in the morning.
Just curious if anybody has seen this, or am i an isolated incident.
-SRTless in Annapolis :sad2:
