1 - 11 of 11 Posts
does anyone know how the washers on the front xenon headlights work, are they supposed to spray water on the lights. i cant figure it out or is it there just for the look..
:) :banana: :wave:
Thank You
David
:) :banana: :wave:
Thank You
David
There's a setting you can make to have them come on when the wipers do.
Rambit
BLOODY ADMENSTRUATOR
doodie300c said:
how do you do that i wanna try it out? :silly:
Howdy Doodie!
To check it out, it is a 2 person operation.
  1. First have a friend sit in the car, ready to activate the windshield washers.
  2. You go to the front of the car, on the driver's side.
  3. Face the car. Now bend way down until your face is about 12" to 6" away from the light washer nozzles.
  4. Hold that position.
  5. With your right hand, signal your friend to activate the windshield washers 3 times in sequence, holding each squirt for about 3 seconds.
  6. Report your findings back to the forum.
Northern Rider said:
Howdy Doodie!
Please wear googles :raincloud :thinking: :lmao:
[/QUOTE]
Watch it NR! That's plagiarizing! :biggrin: :banana:
Funny, but when I first got my car I was outside a store where I could see the reflection of my headlights in their door. I decided I would try out the washers as I had never seen them work. When I tried I didn't see any water- great- so I thought they were broken. After reading a previous post about this very thing I learned that it activated every three sprays. DUH! :biggrin: Another learning experience from this board. :biggrin:
Does ANYBODY read their owner's manual?
I always read my manuals
The manual (page 105) says to use the headlight washers you have to turn the headlights ON and press in on the windshield washer control knob while the engine is running. This will operate the windshield washers and direct a timed high pressure spray onto the headlight lens. It goes on to say the headlamp washers will operate on the first spray of the windshield washers, then every fourth spray of the windshield washers after that.
Rambit
1 - 11 of 11 Posts
