The mods you've done and the mods you're thinking of doing probably won't quite get you there. Your 2013 has more horsepower from the factory than the early ones, so you're ahead of the game compared to us early 5.7 guys, and your Variable Valve Timing is a big help in this regard. I've advanced both of the aftermarket performance cams in my 5.7's to move the power curves to a slightly lower RPM. A well selected aftermarket performance cam will probably give you the biggest bang for the buck. On the early Hemi's, along with a good header back exhaust, these two mods. on the LX's were worth about 50-60 hp. On my 5.7 Jeep, with a super crappy stock exhaust system,, headers, a good straight through cat. back and a cam yielded about 75-85 hp over stock. The biggest choke point on the Jeep 5.7's is the tiny exhaust log manifold. See pix below.....left to right, the stock 5.7 Jeep log, the stock early 5.7 LX log and, on the right, my first set of custom headers for the Jeep.
If your 2013 exhaust logs on the 5.7 are as good as the early (2005-2008) LX 5.7's, shorty headers (I have them on my 05), they won't give you more than about 10-15 horsepower. Good, straight through (no internal switchbacks) mufflers will give you maybe another 10 or so horsepower. An 85 mm throttle body probably won't give you anything other than maybe slightly better throttle response. With the mods on my 3 Hemi's (two 5.7's and one 6.1) I've run the stock 80 mm's, 85 mm ones and 90 mm ones. The only ones that do anything noticeable over the stock ones are the 90 mm ones, but only with a bunch of other mods.. The ONLY thing I can tell is they give slightly better throttle response......no noticeable increase in power. I recently took of the 85 mm one off my 6.1 and put the stock 80 mm one back on. I didn't notice any difference at all between the two.
Adding a K and N (I've tried this too) will give you some additional power, but it'll only be noticeable at WOT. Putting around town, you probably won't notice it. Back in July 2013, Mopar Muscle Magazine did dyno tests on the power lost by the various engine components......water pump, alternator, power steering, AIR FILTERS, and engine oil. The two we can really do something about are the air filters and the oil. On their tests, without any filter vs. a stock paper filter vs. a high flow filter, they found that, compared to no filter, the paper element robbed (at peak power)14.4 hp. and 10.4 lb. ft. of torque, and the high flow filter only robbed 5.9 hp. and 5.5 lb.ft. of torque. 20W-50 oil robbed 16.4 hp. and 12 lb. ft. of torque when compared to 5W-20 weight oil.
Bottom line, IMO, start with a good cat. back exhaust, and then do a fairly mild aftermarket performance cam, one with good street manners.
