Engine light on READING OIL PRESSURE 19 PSI - HELP!
15179 Views 21 Replies 6 Participants Last post by  kevenj
OK I was playing in the car all day on the audio system. I had the negative battery terminal off and back on twice, and I removed the factory amplifier and the 2 black plastic harnesses that attach to the black part on the amp (part reads Siemens).
I put the black part (Siemens) back under the dash, with the harnesses back in place.
Since then I am getting the Engine light on during start, and if I am reading the system correctly (it goes like this: DOOR AJAR, then it is showing OIL PRESSURE 19 PSI (then when you hit the gas the oil pressure reading increases) and then it scrolls to giving the reading of the oil temp as well. I assume these are Codes saying probs possibly with the OIL Pressure or Temp?
Car was running a little hot I though, last night it was running 225 deg after like 5 min of idle. Then it came down to 212-214 after driving a short distance...
Did I mess something up by removing the 2 wire harnesses attached to the black device on the amp (by the way this item I do not think had any connection to the audio as far as I know it was simply attacched to the amp by 2 screws). Or is this a problem that will need to be addressed by the dealer?
21 - 22 of 22 Posts
Actually all the lights were cleared this morning on the way to work! I took the advice of 5point7 and stopped the car, restarted it at the first stop light after I left for work, and they cleared out!
Thanks guys
Paul
19psi at idle should be MORE than adequate, especially when the engine is warm. That would not worry me in the least.
21 - 22 of 22 Posts
