can you put a 2013 5.7L hemi in a 2006 Chrysler 300c its a 5.7L too But Its The older Model Hemi
Yes.
The accessory drive is different, CANBUS is not compatible, your '06 PCM won't run the Eagle, and you'll have to lock out your VVT, for starters.
Not worth the trouble unless you're getting the engine and/or skilled labor for free or at a steep discount.
Yes.
What if i take the intake manifold from the new model would it be compatible with the 2006 5.7L?
If I'm not mistaken and the info is good which I do believe it is, a gentleman told me that the 5.7 eagle intake won't go on the old 5.7 block because it hits the coolant temp sensor. You'd need an intake from a 6.1 or 6.4
