On the bottom and in the middle of my EVIC screen there is an envelope can't find out what it means? does it have something to do with my phone having a un read message?
Thanks bud!It means your car has a message for you in the EVIC Display, probably something like maintenance is due.
Just scroll down through the display using the steering wheel buttons until you see # or messages and it will display the message then you have the option to clear it.
Sent from AutoGuide.com App
Just found this incase anyone else needs this info.Just went outside and checked the message. It says oil change needed. I just did it so does anyone know how to reset it?
That's interesting... So, did it go away?Just found this incase anyone else needs this info.
Vehicles Equipped With Keyless Enter-N-Go
1. Without pressing the brake pedal, cycle the ignition to
the ON/RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Cycle the ignition to the OFF/LOCK position.
Yes...:fing02:That's interesting... So, did it go away?
