1 - 20 of 110 Posts
The LX platform has an elegant architecture as it should being derived from Mercedes Benz engineering. To reach production with price points suited to the Dodge and Chrysler brands some components were compromised by accounting and marketing. Most all brands and manufacturers face the same challenges and those challenges results in similar compromises. With the LX, when driven at anything but the post speed limits you will experience:
Rear End Step Out
Dramatic Bumpsteer
Bush Induced Body Lean and Roll
Damper Induce Body Lean and Roll
Coil Induced Body Lean and Roll
Significant Dive on Hard Braking
Adding sway bars, coil overs, springs and dampers actually make the foundational instabilities of the platform worse. By making one element of the suspension stronger, all other components become comparatively weaker. Take a look at these pictures. They are from a series of vehicles that we have Pedderised. We have been around for 59 years in AU and three years here in the USA. In our collective experience we have never seen bush failure this dramatic. The failures are the results of RWHP, awesome BREMBO brakes and what most OE manufacturers would describe as owner abuse. If you drive your car at the posted speed limits you will not see tears and wear like this. If you are like me and live for a twisty road, an autocross or a track day your car will have similar wear and tear. It will not be a warranty claim unless the Service Director is a family member.
These are not isolated instances of worn / failed bushes. These are from SRT 8s and RT driven as you or I would drive a vehicle with a HEMI. These bushes can be inspected with the car on a life. All we need to do is remove the front plastic undercar cover. Inspecting these bushes is part of the Pedders 28 Point LX specific inspection. So how does this apply to the handling issues of the LX platforms?
Rearend Step Out is directly related to the control surfaces of the sub-frame bushes. The OE bushes ride on a very small raised ares of ridges or bumps. You can clearly see in these pictures how much movement there is with the OE bushes.
Some of the noises that you are chasing on your LX come directly from sub-frame contact to the monocoque as the sub-frame squirms around under acceleration and turning loads. The harder you drive, the more they squirm. The stronger the grip is from larger / stickier tires, dampers, coils or all of these -- the sub-frame twists more and the car becomes more unstable at the handling limits. There is only one solution available for the LX platform to eliminate rear-end step out. Pedders EP1172 Sub-Frame Bush Kit.
The factory installed sub-frame bushes have a control surface of approximately 4284 Square MM. Pedders EP1172 Cradle Bushes provide 26,580 Square MM of control surface. The voids in the bushes deliver NVH standards thisclose to OE, but with vastly improved control. Your suspension is no different than your home. If your foundation is robust you can build with great confidence. Your LX foundation begins with Pedders EP1172 sub-frame bushes. Before you add RWHP, before you add a cool exhaust, before you upgrade your tires and wheels, before you take delivery of your LX -- start with a robust foundation -- Pedders EP1172.
Bumpsteer measure 9mm by our testing. The range of change in the front suspension geometry on the LX driven aggressively is quite large. Combine bumpsteer with rearend step out and you have a vehicle that wants to swap ends when pushed hard. This is critically important for emergency maneuvers on the street and mission critical for those of you who autocross or track you cars. Pedders EP2113 changes the position of your steering rack and reduces bumpsteer to 3mm.
By lowering the mounting hole with an eccentric on the steering rack, we raise the rack in relation to the wheels. The difference in control of your LX with robust sub-frame connectors and an EP2113 Bumpsteer Correction Kit is the difference between a clapped out K car and you brand new SRT 8. It is huge.
Bush induce body lean and roll is directly related to the bush durometer and material. The upper front control arms have very soft OE bush material. This video illustration is not a certified test. It is an illustration of the range of motion created by placing an OE control arm with OE bushes in a vice and wiggling it with Brandon's little finger.
YOU TUBE BUSH VIDEO LINK
Anyone can create a set of rock hard bushes for an platform. Rock hard doesn't translate into superior handling. Most production vehicles are under-tired. The tires are too small for the BHP, RWHP and Dynamic loads created when turning. Your LX weighs about the same as 2 1/2 Formula One cars. Using the rear tire width on a F1 and projecting that out to a similar width based on the weight of an LX your rear tires would each be about 30" wide. Making your LX as tight as a F1 car will just eat tires unless the tire width is brought to a similar level. That means we have to retain compliance in your LX suspension while we increase control. The result is that the ride quality is retained while handling is vastly improved. These diagrams illustrate where the range of Pedders bits fit.
Damper and coil induced lean and roll are the direct result of tuning to the critical damping scale. Think of this scale as a thermometer. At one end is complete control. At the other end is complete comfort. It is a zero sum game. Engineers attempt to balance the needs of the market with control. Audi’s RS series is an extreme example of tuning for performance and control. Even by German Autobahn stands an Audi RS is a very tight vehicle that most Americans and Germans find harsh. A Peddrised LX is more AMG than it is Audi RS. It will be taut, but with no drama.
The OE setup is clearly softer and has more drama over bumps and turns because of excessive motion. I like to take a Pedderised LX out with four passengers. Every bush in the car has been replaced with urethane, every coil with higher riates, every damper higher on the critical damping scale, larger front & rear sways and LOWERED over parking lot speed bumps. All speed bumps are not created equal, but those I have taken LX owners over at 5, 10 and 15 MPH would have been a major drama with OE bit and one person. With five people in the car Pedderised and LOWERED there is no drama. Their jaws drop.
By teaking everything from bushes to dampers to coils to sways we gat control of the LX without harshness. The anti-dive results in more energy being applied to stopping and stopping from 60 MPH to ZERO with a full load is reduced by 7” according to our G-Meter. Visually it appears that braking induced dive has been eliminated. That is not the case, but it has been dramatically reduced.
You can find more information on Pedders LX Packages and Bits at: PEDDERS LX Packages & Bits
No for the bottom line – belive nothing but your own backside firmly planetd in the seat of a fully Pedderised LX. Conact your local Pedder Dealer to arrange a test ride or come out and visit us at the track. Every upgrade and modification sounds good on the internet. The test is you butt in the seat first hand where there is NO BULL.
Great write up! I didn't have time to finish it, but will be back to finish it later tonight or tomorrow. You should post this on the other forums.
What is your opinion of strut bars for the LX cars?
The LX generates substatial torsional loads with BHP, RWHP and weight. A good strut tower bar would appear to be of benefit. Our R & D people are looking at designs and results for an LX strut tower brace.
We invite you to come out to the track and see for yourself what a Pedderised LX can do.
Event Highlights
Autocross
Boxing
Car Show
Chrysler / G.A.M.E. / Pedders Hot Shoe Shoot Out
Drag Strip
Fun Runs on the Track for Special Children
Music
Road Course
You can register by sending a PM or Email to JusticeDeb or [email protected]
Rock'n Box'n
Rock'n Rac'n
Rock'n Rock'n
A portion of the event proceeds goes to charity. A number of Pedders Dealers will be on hand to answer your question and turn a few wrenches as required for your track activities. If you have never drag raced -- come on out, we will have instructors for your first pass. If you have never autocrossed before -- do it her with an instructor. If you have never run a road course -- we'll take you out for a modest hot-lap -- if you don't soil yourself or the car on lap one, we'll do real lap on number two.
Well, this is actually quite depressing to learn.
I'm glad you have a solution for us but I have....er, HAD no interest in swapping out suspension components.
I'd be interested in getting a an inspection just to be sure.
Where are you guys at in the USA?
Hey Pete, us Canadian folk are looking for some love! Any update on install options for Vancouver BC?
Discussion Starter #10 (Edited)
Once you drive a Pedderised 300C your interests may change :saroll:
Pedders has number of Certified Shops around the USA and we are actively looking for more -- INCLUDING Canada. The primary criteria for a Pedders shop is soft. It is the dedication and commitment of the shop to customer service. We can teach bits and alignment, but don't have time to teach customer service culture.
You can find the Pedders Shop Nearest you at our Dealer Locator.
Once you drive a Pedderised 330C your interests may change :saroll:
I'd sure like to hear a testimonial from one of the folks on the forum that track their LX - especially SRT variants. I've had my SRT long enough to be interested in improving its handling, but I have no way to evaluate your option compared to others. I would pay close attention to opinions of NorthernRider, DanRealtor or any of the others that are serious about tracking these cars.
-david
I'd think it would be of interest to hear from Meister as well and Matt Robertson... Cool Vanilla to name a few others.
Please don't misinterpret my post. I like your writeup and am interested in your product. But...its also very expensive and new to this market. Hearing from the luminaries on this site would go a long way towards improving my comfort level.
Tim - thanks for the other names, I knew there were others I was missing, but was having a "senior moment". I had dinner with Grinner this week and got to hear some good Meister stories, so I didn't even have an excuse there...
-david
From my memory bog from another thread, doesn't the whole kit cost in the $7k range, or was it $5k? And then add the cost of the install, maybe 8 hours x $100 = $800. While the kit is beautiful and probably performs up to expectations, that is serious pocket change to plunk down.
I followed the link from another post to the Pedders web site and it looks like the complete kit with springs and dampeners for all wheels runs about $3K. If you drop the springs and dampeners out of the kit it looks like about $2K, plus install. Not cheap by any means but better than $7K. There is just no end to how we can spend money on our cars is there?
Ok. Not sure why the higher numbers stick in my brain.
$3k isn't a bad deal. I paid $1,420k for KWv2's plus $340 for Hotchkis sways = Total $1,760. An extra $1.2k might be worth it for the rest of the package. I also paid $400 for the KWv2 install and $265 for the Hotchkis install.
If I was still stock and looking to upgrade, the $3k plus $800 for the install would be on my short list. But it would be good to have someone that has done the upgrade give an objective comparison.
JusticePete,
I need to improve my suspension, so please, HELP!
My 2006 300C SRT8 rides on 22 inch wheels with 265 pirelli scorpion tires. Problem was, I badly needed more clearance because we have to many bumps in my location. I solved that, buy handling is uncomfortable, and I should be changing my wheels back to 20 inches next month.
I would still need the additional clearance from the floor, which may be obtained by using bigger tires, but would like to keep/improve handling, and certainly improve comfort!!! I love my car but our roads are quite bad!
Do you think any of your products can help me to achieve what I am looking for in my car?
Thank you for any help you can provide!
Just300
Discussion Starter #19
JusticePete,
Just300
You need more clearance to the road becuase you are bottoming out the undercarriage to the road bed or bottoming out the suspension on the bump stops?
Discussion Starter #20
-david
David,
One of the strengths of the Pedders Dealer Network is that we make cars available for test rides / drives. The West Coast Business Development Manager Mike White (on the forum as dms for Doing Mike's Sh--) just completed the Fairfield Pedders / Cadillac / Chevrolet shop certification and demo HEMI. Fairfield is in the San Fran Bay area. Bob Morreale at Precision Motorsports near Tampa Bay has his personal Pedderised R/T. Rich, Brandon and Justin up at Norpac in the Northwest have a Pedderised SRT 8 for demos. John Panfil at Anthem Motors in Phoenix has a Pedderised Charger R/T as his personal car.Our other Dealers either have a car in process or have worked it out with a customer to provide demos. The Desert Madness event is a MAJOR demo event.
Pedders is offering special pricing for the cars we use to for in shop education. Ted Wiens i looking for a special customer right now. The hard core guys you mention are welcome to contact me or any of our Dealers to see if there is a specially priced promotional suspension available. We allocated one to each Pedders Dealer for exactly this reason. Have you hardocre track guys contact a Pedders Dealer.
If you already have KWs and / or Hotchkis sways on your 300C they are not working any where near thier potential. The foundational instability of the bushes prevents them from functioning at optimum levels. A Pedders Track II bush kit (no dampers, coils or sways will transform the car, but don't take my word for it.
Read any of my posts in any forum and they always say the same thing. Take a demo ride / drive. Don't buy by charts, graphs or data. Get in a Pedderised car -- be be warned. Test riding / driving a Pedderised car has been know to cause severe suspension envy and sleepless nights. Check with your accountant before taking a Pedderised demo. Doctors have determined there is only one known cure for suspension envy --Pedderise!
1 - 20 of 110 Posts
