· Banned
When you go into the diagnostic screens on the EVIC, it will show you "raw" and "avg" temperature readings. Does anyone know which sensor and where that sensor is located, that generates that reading?
· Premium Member
If I am thinking about the right one, according to the service manual...
"The ambient air temperature sensor is a variable
resistor that monitors the air temperature outside of
the vehicle. The ATC system uses the sensor data to
maintain optimum cabin temperature levels. The ambient
air temperature sensor is mounted onto the bottom
of the front bumper beam."
· Banned
Not the answer I was hoping for, but sounds like you nailed it. Thanks for the help!
Slightly toward the passenger side, down low. It's visible when you remove the little Mickey Mouse snap on cover panels...aka the place I always lay my tools.
