1 - 8 of 8 Posts
I researched the different exhaust available but what is the difference between the mopar cat back and the borla 3' . Please give me some feedback on what you would buy if you were wanting something that's not to loud when cruising but gives an awsome sound when you get on it. Thanks
The MOPAR cat back is made by Boorla and has Boorla on the tips still! It's just a bit quieter from what I'm told, but I don't have any data for you. CHeck with Ted at MPSC, our vendor, he should be able to help you.
exhaust mod
You can take the 300c to a muffler shop and let him remove the suitcase muffler. You will have a snarl when you pull out or accellerate hard, but at cruising you do not hear the exhaust. Very in-expensive mod, that will save you about 900 beans, not too bad a deal. :)
You might also want to check out the threads on the zoomers exhaust, kidcoastal has some links that give you an idea of the sound. I've heard the borlas on a magnum and although its not bad there is a slight drone when going on 4 cylinder cruising mode, not a problem with the zoomers I'm told. I had been waiting on the corsas but ultimately with the uncertainty of the corsa system and the rave reviews of the zoomers by kidcoastal and on the lx forums I took the plunge with zoomers.
Borla vs Mopar
bfunk
In answer to your question....All Mopar performance parts, including their system built by Borla DO NOT come with a warranty. This means if something happens to your system they will not back it. Borla on the other hand carries a million mile warranty and does back it 110%. Check out our group buy on the Borla system.
Correct, Mopar performance parts carry NO warranty, it's right on the website. Very poor. I see no reason to buy Mopar, there are other alternatives. GM even warrants the Z06 if it is taken to the track (not in a racing series).
Hey, that's good to know, thanks! I did know from speaking to Ted at MPSC (He's at my local dealership) that even the MOPAR exhaust isn't covered by Chrysler's warranty because it's a performance add on, so it's good to know that the Borla one has it's own, should the need arise!
1 - 8 of 8 Posts
