1 - 1 of 1 Posts
Asking $500.00 shipped.
T20001bd
2000 Watt Class-bd Mono Amplifier
The T20001bd is best suited for subwoofers-BIG subwoofers. With 2000 watts + of efficient BD class power it can easily drive even the most power-hungry subwoofers. A high-output alternator and large capacitor are recommended.
MSRP $1,499.99
Description Value
CEA-2006 Compliant
Number of Channels 1
Rated Power
continuous power 750W x 1 @ 4-Ohms
1500W x 1 @ 2-Ohms
2000W x 1 @ 1-Ohm
Total Power
total sum of 'rated power' 2000 Watts
Bridgeable Yes (bd-sync2 cable required)
MasterSync
PowerSync
Crossover Controls Low-Pass (LP): 32-250Hz 24db/octave Butterworth
Infrasonic filter: 27Hz 12db/octave
Tone Controls Bass: 0dB to +18dB @ 35-70Hz
Phase: 0/180 degrees
Signal Input Low level: 1 RCA pair
Signal Output Low level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Fan cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal Status
Speaker Protection
Circuit Topology Class Class bd
Frequency Response 20Hz to 300Hz +/- 0.5 dB
Shipping Weight 28.0 Lbs.
(12.7 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 23 (in)
6.6 x 32.5 x 58.4 (cm)
1 - 1 of 1 Posts
