1 - 1 of 1 Posts
For sale asking $350.00 shipped. Works like it is brand new.
T8004
800 Watt 4-Channel Amplifier
The T8004 offers tremendous flexibility when wiring multiple speakers since it’s designed for lower impedance loads. A natural for powering component speakers, you can also bridge the rear channels to add a 4-ohm DVC subwoofer. A capacitor is recommended.
MSRP $899.99
Description Value
CEA-2006 Compliant
Number of Channels 4
Rated Power
continuous power 50W x 4 @ 4-Ohms RMS
100W x 4 @ 2-Ohms RMS
200W x 4 @ 1-Ohm RMS
200W x 2 @ 4-Ohms bridged RMS
400W x 2 @ 2-Ohms bridged RMS
Total Power
total sum of 'rated power' 800 Watts
Bridgeable Yes
Crossover Controls High-Pass (HP): 40-4kHz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-4kHz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch
Infrasonic filter: 27Hz 12db/Octave
Tone Controls Bass: 0dB to +18dB @ 35-70Hz
Signal Input Low level: 2 RCA pair
Input switch: 2/4 ch.
Signal Output Low level: 1 RCA pair
Preamp Output Crossover: HP/AP/LP 12db/Octave Butterworth
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Fan Cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal Status
Speaker Protection
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 0.5 dB
Shipping Weight 26.0 Lbs.
(11.8 Kg.)
Dimensions (HxWxL) 2.6 x 12.8 x 23 (in)
6.6 x 32.5 x 58.4 (cm)
1 - 1 of 1 Posts
