This FAQ is currently in Development. If you have any suggestions or corrections please reply to this post. Thanks!
General Description:
Navigation Radio (model designation REC) combines a 5.8-inch full-color display, AM/FM stereo, 6 disc CD/MP3 Player and Navigation System that utilizes DVD technology, all in one handy unit. This sophisticated, yet simple-to-use navigation system guides you to your precise destination through the use of Global Positioning System (GPS) satellite technology and an onboard computer. The system offers turn-by-turn route guidance with voice instruction, automatic re-route calculation, unique smart-spelling feature, extensive listings for point of interests and enough memory to store 100 personal addresses. Unit includes a geographic DVD with routing directions for the entire mapped United States and parts of Canada. The radio features 12 AM, 12 FM, and 12 Sirius Satellite Radio pre-sets. This system is Sirius Satellite Radio capable and displays station names, song title and artist. To obtain Sirius Satellite Radio, a satellite receiver/antenna kit and subscription to the Sirius service is required. See Sirius FAQ. It uses the new CAN bus system and CANNOT be adapted to older vehicles.
Frequently Asked Questions:
2. The Center console bezel with the larger opening for the NAV Unit for your model 300.The Bezel costs anywhere from $75 to $100 depending on where you decide to purchase. Part Numbers:
Model: 300 Base - WX57DX9AA
Model: 300 Touring/Limited 1AQ46AAAAA
Model: 300C - XB311ZBAA
Model: SRT-8 1AP611D1AA
3. Navigation Antenna (I'm unable to find MOPAR part number on this item)
4. Navigation DVD "AC" Part # 05064033AC $50-100 off ebay
No. The system is designed to accept MOPAR DVD navigation disks exclusively. There are currently no modifications to allow this.Does the navigation system play movie dvds?
Yes. AVelectronic.com has developed a way to tap into the RGB signal on the LCD screen to allow video input. You must ship them your Navigation unit for the hack, and call them to prearrange. Cost is $575 for the Video Switching unit, and $100 for the Modification itself. Turn around time is about a week. The system supports up to 4 Audio/Video inputs. AVelectronic has become a common provider of Navigation system modifications and currently supports many other vehicles. You will void your Navigation Warranty by having any modifications performed so be aware.Can the Navigation unit be hacked to allow an external video input so I can use a TV Tuner, Backup Camera, DVD player, or Gaming Console?
Absolutely. The installation process involves swapping the Silver Center console bezel with the Navigation Bezel, and swapping out the AC Vents, AC Controls, ESP/Airbag module, and Analog Clock. 4 Screws hold the Radio in, Navigation or not. Its quite a simple modification. A phillips head screwdriver and 4mm socket are all that is required.Can I add the Navigation system to my 300c myself?
1. A REC Navigation Part#P56038646AJ system from a Dodge Durango, Chrysler 300c, Dodge Magnum, or Jeep Grand Cherokee. You should be able to find a used one for $800 on up off ebay or the forums. Be Sure that the unit you purchase comes with the Antenna and Navigation DVD because the dealer charges a lot for them. New the units will cost around $1500 on up. The cheapest new ones I have seen are on ebay for $1350.What parts do I need to purchase to convert my car to Navigation?
Anywhere under the dash. Mine is located on the metal bar behind the AC vents in the center of the console. Works great. Never any drop outs.Where exactly am i supposed to mount the NAV antenna?
The nav has sound and visual alerts (on both the screen and on the evic) and it gives a realtime distance to turn on the screen.How are you prompted for turns? Voice, visual?
Updates are issued every so often and we have to purchase them seperately from the dealer.How often do you get updates to the DVD? Do they send you DVD's annually?
The voice over coveniently turns down the stereo volume when she has something to say. The voice can be changed to an audible chime in the settings.Does it mute the radio / CD volume to speak, or does it talk over it?
Nope and hacking it isn't going to be easy. Thats the lawyer screen!Every time I start the car, there's an annoying warning on the nav screen, and I have to hit Enter to clear it. Is there any way to disable this "feature"? Thanks!
Check your gauge cluster brightness setting on the knob next to the headlight knob. It is most likely set to "Full Brightness" which means the navigation unit is always bright.During the setup of my 300C/Nav, it was defaulted on "automatic" setting for day/night. However, when driving at night time, the navigation does not dim itself. Is there another setting that I should have chosen? It's somewhat annoying at night.
Nope. Talk to the lawyers.Is there a way to disable the safety feature that does not allow in motion use of some functions over 10 mph?
No touch screen on this unit, but it is easy to use. The little knob can be used as a joystick (rocked up/down or left/right) to select items, or rotated to zoom on the map.Is the unit touch screen? How is it controlled?
