Note that there are no mods to the unit. It is simply programmed differently. There are sometimes some quality issues at the Indiana plant, but none reported so far with the ZF designed box, just programming.
This is a very versatile slushbox used in Bentley, BMW, Audi, Jaguar, and many more vehicles. It even works as a hybrid trans with an electric motor sandwiched in there.
Hi Steve,
According to Chrysler the unit was indeed slightly modified with an extra clutch and separator. Also, some units can have different types of oil pans. Please refer to the document link below.
http://courses.chrysleracademy.com/MT201211/shell_popups/pdf/Reference.pdf
The 8HP45 and 845RE transmissions look
nearly identical from the outside. It’s only
when you get inside the case that things
start to look different (Fig. 4).
While some internal components will
share part numbers, most internal
components will not be interchangeable
between the 8HP45 and the 845RE.
For instance, while the clutch packs look
very similar, they are not interchangeable.
Looking a little closer at the 845RE clutch
packs, the D clutch has an extra pair of
separator and friction plates for improved
vehicle performance (Fig. 5).
