I have a 2005 300 Touring model. The drivers side fog light has burned out. How do I replace the bulb? Do I need to drop the bottom panel and get at the bulb from the back side or am I missing how the front panel is retained?
Thanks,
Bulsi
you can turn your wheels all the way right and access it thru the inner fender panel, but then you have to replace the fender clips as they are a one shot deal.
I replaced mine with body clips and bolts, got tired of popping the plastic clips..
Going up from the bottom with the front part of the belly pan is your best bet...
