HI
I have a 2009 Chrysler 300c CRD and my fog lights arent working. I have checked the fuse and it is ok. I have tested the fog light connector to make sure it is getting 12volts and it is fine. I have tested my fog light bulbs and they work fine. Does the 2009 have a fog light relay and if so where is it located? I saw a youtube video for a 2007 model where someone took a wire where the the front fog lamp relay is located by connecting a wire between points 30 and 87 to fake the system into thinking the relay has been triggered to make sure his lights come on so that way he knows the problem is with the headlight switch but I dont know which relay it is and if you can do it on the 2009.
Does any one have any ideas on what I should do to fix this problem without taking car to dealer?
