1 - 1 of 1 Posts
F1 Fuel Pressure Regulator
Minimal pressure variations in high output and/or multi pump fuel systems for up to 2000 horsepower.
Dual -8 o-ring pressure ports
-8 o-ring return port
Flourocarbon/Nomex diaphragm gives highest possible strength, heat, and chemical resistance--Use with all fuel blends.
Contoured internal geometry and optimized valve design has chatter free operation for highest possible stability and reduced fatigue of all internal components.
Adjustable base fuel pressure from 25 psi to 70 psi.
Boost Referenced 1:1.
Fine pitch adjustment screw for precise setting of fuel pressure .
Standard 1/8 NPT fuel pressure port on front of regulator body.
Upper spring hat is "indexable" for convenient positioning of 1/8 NPT pressure port.
1 year warranty.
1 - 1 of 1 Posts
