Hello guys, I need advice with the suspension on my 05 Chrysler 300c. Recently I changed all the front control arms upper and lower pretty much everything, including ball joints and sway bar links, except the spindle arm. Also replaced the struts and spring assembly on both sides. Replaced rear shocks also.
I noticed that passenger side sits 3/4 inch lower than driver side. I can see the difference when I'm driving I can kind of feel the unbalance. It's driving me nuts.. when I go over bumps the driver side spring and shock responds I can feel them working responding. Now with the passenger side I don't feel that spring and shock feed back as I go over road bumps. The spacing on the coil looks the same on both sides when the car is on the ground. Is 1 shock spring taller on one side that other?.any suggestions?
I bought some shock and spring kits from O'Reily's auto parts.. as a set for the fronts, and set for the backs the back.
I just changed the shocks which the springs are seperate on the back.. all the upper front control arms are new and all the lower ones, front and rear that is. Also the sway bar links and bushing are new. Also lower ball joints are new.. I feel like I have more roll when I hit sharp corners o. The passenger side. And again 3/4 inch lower on passenger. Funny thing is if I jack up the car off the groubd, and then lower it.
It's even on both front sides. But after driving then it drops on The passenger side...
I would raise the issue with O'Reilly's. The kit may use some cheaper springs that aren't up to OE specs or quality rigors. One spring may have sagged. Or take the time and effort to replace the front springs with the factory springs if you still have them. Though OE springs tend to be pretty long so you may consider having a shop do the work. The cheaper spring compressors that most DIYers use tend to be difficult to use to install OE springs. If you decide to take it on yourself, grab as many coils in the compressor as you can. Another option may be to take the coil-over assembly to a shop with the factory springs and pay them to only swap out the spring and so the removal and install yourself.
Discussion Starter · #7 ·
Yes I swapped the spring assembly from one side to the other and it's the same on passenger side. When I bought the car long ago .I put on 22inch wheels. Sum how my girl cracked my rim in half. But I don't remember seeing this passenger side 3/4 of an inch lower. It used to pull to the right. This was long long ago. I'm wondering if sway bar is bent also....the rims I had were fixed tho. I didn't know. They were welded repaired I notice weld spots when I took the wheel off.. to crack a rim would take a hard impact. N major damage to something. But there wasn't any..maybe sway bar?
Discussion Starter · #8 ·
I have changed pretty much everything for suspension except spindle bar and sway bar. When I lower after having both wheels off the ground it sits level. On both side. After a while then I see the drop of 3/4 of an inch on one side. I bought decent spring kits on the 300 price range compare to oem dealer wanted like 500 to 600 here in california. Strut towers don't seem damage or bent or anything...
I would guess that you are tightening the suspension mounting bolts while the wheels are hanging, in effect you are preloading the rubber bushings,
you need to have the suspension carrying the weight of the car before tightening the bolts that are through the bushings, this will put the suspension bushings in a unloaded state and will also prolong the life of the bushings.
Reactions: etyrnal
If you want to check the sway bar, disconnect the end links and see if the suspension corrects itself. Then check to see if the ends of the sway bar sit at the same height.
As for a wheel crack, with 22's, I'd imagine you'd be running lower profile tires. Smaller sidewalls equates to less impact resistance. It's also unlikely that aftermarket wheel companies will put the wheels through the same rigors of testing that OE's do. Ford apparently runs their cars up a curb-like profile according to an article I read regarding the GT350R Mustang. Not to mention the proving ground tests which involves some pretty aggressive road surfaces. Either way, the cracked wheel itself should have no effect on the suspension but could indicate they damage occurred at some point. Might be helpful to put it up on ramps so you can inspect it with the suspension loaded and start talking measurements of both sides and compare.
2014 CRD
Ah then it doesn't sound like it's the spring assembly if it's the same side to side.
Have you checked the suspension arms for damage? Hitting a wheel badly enough might have bent the suspension? Just a thought
Discussion Starter · #12 ·
*boro al*
I had the suspension replaced at a shop.i bought all the parts and paid to have them installed and have the car alligned. I don't recall the car being like that short on one side.But yet I don't remember it was a year ago or more now.
All arms and ball joint and sway bar links and sway bar bushings were replaced. Along with front springs and rear schocks.
But again I never paid attention To the lean on the passenger side. I did swap spring from from one Side to other. The Wheel that cracked long ago. I bought used as a set, But one was fixed. I noticed welding on The inside of rim after wheel broke. That's how they determine they were fixed other than that they look flush on The outside.. I will try the sway bar disconnect and the loosening of the upper control arms and lower control arm bolts and let it rest on the suppension and tighten them up..
i know this thread is old but it’s the only discussion i can find online that mentions the issue I am having. My front passenger side also sits 3/4” lower and I cannot find the issue. We’re you ever able to figure out what component was causing your problem?
