Okay guys I could use an assist here. My 2010 300C SRT8 has developed a problem that I am not familiar. First began at interstate speed when I applied the brakes moderately and the whole car began to shake violently, along with the steering wheel, and appeared to be coming from the front end of the car. Releasing my foot off the brake did not stop the shaking until the vehicle speed is around 35 to 40 mph. The problem has become worse and no longer have to be traveling at highway speed for it to occur. Making this problem more interesting, it does not occur every time, it is random but not rare, in occurrence.
Being an IT services delivery professional, good troubleshooting practice one must ask what was the last thing that changed before the problem first occurred? I noticed uneven tire wear on the outsides of my front tires and went to have alignment done. I was told that they could not properly align all wheels as 2 control arms one front one rear rubber bushings had worn noticing that the front control arm required spring compression and dropping a significant amount of other steering and suspension components took it to a shop to have them installed. I believe this is when I encountered the first occurrence. I took to the alignment shop hoping they would see any issues with the install. Instead they told me they were able to align all four wheels and only one wheel was out of specs and that was nonadjustable camber on a rear wheel.
The brake pedal does not indicate a warp of rotor, but replaced the fronts anyway since both shops were telling me that's the problem, when I knew better. Checking similar issues on this forum, I noticed comments about problem could be with a worn steering box but when I turn the wheels left and right I notice no slop or play under power or manually when vehicle is lifted. There is no slop or play in either wheel hub indicating main wheel bearing issue. Another suggestion was a worn tie rod; which makes sense to me. However, visually inspecting the joint boots, they are intact with no cracking and no grease escaping the joints.
What in the name of Chrysler is going on with my car!? Thanks in advance for all thoughtful responses or follow-on questions...
Regards,
Don
Regards,
Don
