1 - 20 of 43 Posts
Chrysler 300 Angel Eye Kit
SMD Ring Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. Diode Dynamics' angel eyes are the highest quality and brightness available. We encourage you to shop around, you will not find better angel eyes for these prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
Our multicolor rings use SMD technology, a modern type of LED that provides a bright forward-firing light, creating a circle of light inside the headlights.
Our newest product, RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a WIFI controller option which allows you to control them via smartphone app.
Kit includes:
  • Four (4) Multicolor RGB SMD Rings, fitted for your vehicle
  • RF 28-Key multicolor remote, to change the color OR Upgrade to Wifi controller
  • Diode Dynamics Plug-and-Play Wiring Harness
  • Installation guide
  • Three-year limited warranty
We use custom-manufactured SMD rings through our top LED manufacturer, with high-grade AAA resistors and LED chips. They are highly durable, with a black backing color. The LEDs go all the way around the ring, for no "break" in the light as with other angel eye designs, and are ten times brighter than old fiber-optic type rings.
Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Chrysler 300 Angel Eyeshttp://www.diodedynamics.com/store/led-bulbs/angel-eyes/chrysler/300.html?utm_source=300cforum&utm_medium=forum&utm_campaign=angeleyes
If you have any questions, please don't hesitate to post, PM, email [email protected].
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Replaced the dull CCFL halos with our HDHalo switchbacks! Dezert Lighting
Holler when you guys get into the second gens!
DD Nick, do you guys have any halos that are not the square dotted kind (not sure of their technical name) but rather the solid rings like Plasma?
We have a variety of styles available, from CCFL, SMD, to the COB ("Plasma") as some call it.
If you'd like more information, feel free to email us: [email protected]
Thanks!
Nick C.
Nick, will you please link me to some of the Plasma halos I had asked about before? From what I can tell, the website only shows variations of SMD LED. Thanks
We refer to them as COB rings, since that is the actual style of ring they are.
Plasma is a marketing term coined by one of our competitors and has nothing to do with the ring technology involved.
We have a very large shipment of COB rings arriving within the next two weeks. I will post an update when they arrive and provide more information.
They are the highest quality COB rings offered on the market today. The brightest and most reliable, with an aluminum backing and excellent heat dissipation.
Feel free to call if you'd like more information: (314) 205-3033
Thanks!
Nick C.
Thanks!
Nick C.
Did your COB's come in yet?
Discussion Starter #12
What size would I need for a 2013 300S with the lighting option (cob ring) and how much????
I would hold off on COB angel eyes. We will be releasing our new models later this year. Our engineering team has been working on them for the past several months.
We will be manufacturing them right here in St. Louis, and they will be far better than anything currently available
Nick C.
Nick C.
Do we get beta testers discount if we order them immediately?
Nick will they change colors. Can you post some picks of them on a 2nd gen 300..Will they be plug and play..
1 - 20 of 43 Posts
