1 - 11 of 11 Posts
I have read "pull fuse # 11" a few times. Can anyone please explain what it is and what it does?
Here you go.......
http://www.300cforums.com/forums/441923-post7.html
Pulling fuse 11 allows your car to re-set/re-learn your mods or clear any CEL's related to the mods (after checking the CEL code ..of course). As has been said..it's a good thing to do from time to time so that if you have been driving conservatively (for shame....:biggrin: ) you can '' correct '' your cars adaptive learning capabilities and turn it into the animal it was designed to be....:) .
Fuse 11 is in the front fuse box terminal under the hood. Look @ the underside of the cover, and notice the embossings. Also, note that this is inverted from what you might think.
Fuse 11 is a 20 amp yellow fuse. See below.
Thanks, I'll try it. I imagine it is to be pulled for 10+ seconds and replaced? Also, I notice you have a srt8. Is it the same for the 5.7?
Yep . It's the same . I leave it out for like 30 seconds or so . Good luck ..
Thanks again.
It's beige on the 07's
what about the 3.5?
I looked at the lx service manual and there is no deference in the fuse box layout between the models. So it should be the same.
On the 08's it's no.2, beige 25 amp.
1 - 11 of 11 Posts
